Thanks
Help! Modification WS2500 rain-sensor & WSWIN...
dino77
Hallo!
I have modified the rain-sensor of the ws2500 having increased the area of . from 0.0133 to 0.0380 meters/squared (using a funnel of diameter 22 cm). In WSWIN it is possible to modify to resolution of the rain-sensor? That is to carry it from 0.3 milimeter (originates them) to 0.1 milimeter (after the modification). With my modification, every release of the “splinter-bar” corresponds to 0.1 milimeter; but in WSWIN I do not know like setting up it.
Thanks
Thanks
dino77
Danke Werner!!!weneu hat geschrieben:Hallo,
lo fa cosi:
"Statione meteo" --> "calibra quantita di pioggia"
Adesso "fattore di tartura per il sistemo di misurazione della pioggia" --> 0.100
Adesso WSWIN prende 0.100 invece di 0.360
Ich hatte es schon gemacht, aber ich Konvertiere die Datei und hatte nicht das richtige Regenkalibrierfaktor in "PC_WS Datei-konvertieren" Fenster einsezt!!!
Jezt habe ich verstanden, ich war ein wenig abgelengt!!
Vielen Dank bye bye
